DULUX OVERHAUL
07 Feb 2015 22:06 - 07 Feb 2015 22:29 #1
by outyonda
Last Edit: 07 Feb 2015 22:29 by outyonda.
07 Feb 2015 22:23 - 08 Feb 2015 11:56 #2
by outyonda
Last Edit: 08 Feb 2015 11:56 by outyonda.
08 Feb 2015 07:42 #3
by Outback Jack
Outback Jack replied the topic: DUELUX OVERHAUL
Top one looks like an XT, bottom is an LT. Or is it the same vehicle but changed to an LT front???
The beauty about and OKA is it is rebuild-able. If it was a Landcruiser/Nissan etc etc it would be a write off not worth repairing.
350 is not where near that bad. But its getting a complete refresh.
Still not sure which to keep 351 or 281........
- TH
08 Feb 2015 09:31 #4
by TH
Cheers, Tony
TH replied the topic: DUELUX OVERHAUL
Looks like an XT with a facelift
Cheers, Tony
08 Feb 2015 11:46 - 08 Feb 2015 12:44 #5
by outyonda
outyonda replied the topic: DULUX OVERHAUL
1st is XT #0--
2nd is LT #3--
the before & after is same same
2nd is LT #3--
Last Edit: 08 Feb 2015 12:44 by outyonda.
08 Feb 2015 12:34 #6
by Outback Jack
Outback Jack replied the topic: DULUX OVERHAUL
Cheers Brett.
Thought that was the case.
08 Jan 2019 20:11 #7
by Holmz
^That^ looks good in the snout.
I suspect I need a different tunnel for a wider radiator?
Or does one use the same on an XT, and then a wider intercooler?
Holmz replied the topic: DUELUX OVERHAUL
outyonda wrote:
when you strip it down, it isn't that bad, a few bits of RHS, new skins, paint & wallah, flash one again!!
2 different OKA's but the LT was worse, no bog & goolastic to amplify the rust.
