- 2012 Maintenance Archives
- September 2012
- Shock absorbers - recommendations
I'm after a few shock bushes, the Monroe part# is LS54 but tried the local Repco and Autobarn and they rang Monroe and Monroe said it's an American part number and they can't help... What part# have others used?
Alister
Suggest you ask them (or TruckSpring , where I got my airbags from), I've found US companies quick to respond and have huge inventories of parts.
I found the bushes difficult to remove and replace since the shockers have an internal tapered shape.
Thanks again for the info! I found the flogged out bush quite easy to remove as it had worn through on one side but the other more complete but perished bush looks like it'll be a bugger. I think a press may be the way to go... I've gotten onto a place in the states who may be able to send shocks and extra bushes so i'll post if they're able to help.
Alister
Do you have pictures of your front dual shocks?? The LT`s have a different shock tower for dual shocks. Mine being an XT doesnt have the correct shock towers, so I am going to need to make something up to fit the dual shocks.
I have already fitted dual shocks to the rear.
The shocks I am using are here.
Power Down
Part number is RT41010, I have two on the rear and will have two on the front.
I was going to investigate the possibility of just welding a new mounting bolt to the existing tower, but the slope on the leading edge may make this impractical without a large wedge to line things up.
I also have front airbags and their lower mounting plates will get in the way.
Anyone got any other thoughts?
My idea is to use some box tubing with a bottom gusset. I will post pictures up when I have done it.
I will use the old shockie post from the rear. They was cut off when I installed dual shocks for the rear.
I'll be interested in your solution. Welding up the inside of the tower will be tricky with the floor pan in place.
I am hoping having two shocks actually reduces the load on each shock, therefore reducing the damage you experienced. Time will tell I guess.
You'll need to do the Gibb River Road to test it.
The guys in the workshop couldnt work out why I even bothered with dual shocks.
I finally got onto ordering the Powerdown EB219 bushes and the best supplier i found was Truckline, i think they have distributors all over the country but my closest was:
2-10 Decor Drive,
Hallam VIC 3803
(03) 9702 3344
Alister
Another road that needs renaming to reflect the current status.
Gibb River Highway, Birdsville Highway, Strzelecki Highway
- Peter334
OBJ and LT owners, just wondering what you've used as the dimension in the pic below? Wondering if the shocks are perfectly parallel or can rely on bushes taking up the slack a bit during full suspension travel?
Also, OBJ your new mount is slightly lower than the other, what's the reason for this (was it just so you could fit the mig gun in above the bracket?)?
Alister
I am hoping that in the future Al from OKA will have the LT shock towers, I would then replace what I have done. They are parallel and will be neater.
They look like new shackles with different shackle bolt's to standard OBJ, explain???
