Van Truck
- Kav1050
The rego papers state that it is registered as a VANTRUCK. My understanding of this is that it is already licensed as a Duel cab with tray or is that a diffrent description?. The body that is on it now was made purposely for the SA government, they probably had ADR approval or maybe they didnt and when it was registered in WA they just transferd the description at the MVR.
Does anyone else have a duelCab with tray from factory that says VANTRUCK on rego papers?
I Don't think the fact that technically im changing form steel tray to aluminium would have an effect on the twisting and movement of the chassis?
OKA 423 Shane and Lisa
- Paul and Sue Crompton
Paul Crompton - OKA 168
Registration bodies Australia wide have great difficulty understanding that the OKA is a multi-functional vehicle (cab-chassis) that can be supplied with different factory bolt on modules/trays or can be fitted with a custom tray like many truck/utes.
They will invariably want an engineers certificate if asked if for no other reason that this absolves them from a/. having to make a decision/determination and b/. any liability issues. Like all government departments the first goal is CYA, un-neccessary expense and customer inconvenience is a non issue. The best advice I would give is 'don't ask the question if you may not like the answer'
A more practical approach may be to ask you local registration authority something like................" I'm looking at changing my old style heavy steel truck tray to a more modern and lighter aluminium one, what do I need to do/know ?", and go down this track, I hardly think you'll need an engineers certificate for this. I wouldn't mention an enclosed back at all, why risk creating an 'issue' where there isn't one ?.
What I would consider as part of 'replacing your tray' is re-defining your tare weight (assuming the numbers on the door are the same as on your rego papers). At 4660 Kg this means your load capacity is a mere 5500 - 4660 = 840 Kg.
It must be one bloody heavy box on the back.
The LT cab-chassis weighs in at 3000 Kg, a factory dual cab module is 358 Kg for a total of 3358 Kg, so does this mean the back half weighs 1302 Kg ? Even allowing a bit for passengers etc, it's one heavy tray.
Deano.
I think the bus module is around 1 tonne with seats etc etc
- Kav1050
He asked why i was doing it and i explained i wanted do build a new aluminium tray, he then said because i am changing it i will need an engineers certificate. I did not try to explain to him that the one chassis was designed to take multiple variations of body's.
I cannot find any definition as to what a VANTRUCK means exactly, there is no sheet i can find on their website with the abbreviation of body types. I'd be interested to see what description other OKA's have been registered as and what configuration they were original when first registered.
If VANTRUCK = Duelcab with tray then ill be fine. Im Also interested in this for insurance purposes.
I Plan on taking the back of this Sunday and i will be weighing it on the overhead crane scales, so i will post it when i know what the weight is. I'll just do it bright and early Sunday morning and get the missus to follow behind in her car and sneak it home. Only 10 Min drive.
Kav
You will notice a height difference, you may need to adjust the brake load valve as well.
- Kav1050
The adjustment for suspension is on the max but when the tray goes on and the SC1 camper on top of it fully loaded i think it will come back to a fairly weighty set-up again so ill have to see how that goes.
I will take it to a weigh bridge and see what the weight is after all camper goes on with gear in it. The boat will come in at around 1.3 to 1.5T when its finished too.
- Chris James
Chris & Shirley 096
But I think you get up to speed on a dirt track and hit the brakes. Or if you have access to a brake roller, that would be better.
You will see if the front it working more than the rear, then you adjust the rear valve so it is working front and rear.
- Kav1050
- Hal Harvey
When I started converting the big bus I had to get it registered as it was previously a tour bus with commercial plates.
Ended up on the rego papers as a panel van - forty feet long, 12 feet high and 17 tonnes tag axled shaggin' waggon.
- Oka Parts
we had to have this requirement at the old factory for vehicle road testing.
OKA Parts Australia, 24 Murphy Street, O'Connor WA +61 892236195
- Kav1050
- Frank
- Kav1050
- Kav1050
