OKA Paint Colour
01 Nov 2012 12:36 #1 by dandjcr
dandjcr created the topic: OKA Paint Colour
Forum Home > OKA Maintenance > OKA Paint Colour
From Tony Lee:
Thought I might be able to find it on this site but can't.
Anyone know the code/reference/??? for the matching white paint colour
May 1, 2010 at 1:07 PM Flag Quote & Reply
From Terry McLaaren:
Hi Tony
Paint Type: INTERTHANEIF
Colour: White
Code: 452202
The above is quoted direct from Oka for both XT and LT.
Regards Terry
May 1, 2010 at 1:09 PM Flag Quote & Reply
From David Hallandal:
OKA paint code for XT/LT:
Interthane Product: 3/207-00010418
Four-litre kit (Two-Pack, three litres of paint plus a one-litre hardener)
NT OKA:
Toyota 058
This was supplied from OKA.
May 1, 2010 at 1:11 PM
21 Nov 2014 14:58 #2 by TH
TH replied the topic: OKA Paint Colour
These are only product codes. Does anyone have the correct paint code?
Not even OKA Parts has the correct paint code number.
Cheers, Tony
23 Nov 2014 15:12 #3 by The Worb
The Worb replied the topic: OKA Paint Colour
Hi Tony,
I took a sample to an automotive paint shop and got it matched.
They did a good job and with the correct paint technique you can't
tell the difference.
Cheers Brian
23 Nov 2014 15:27 #4 by Peter and Sandra OKA 374
Peter and Sandra OKA 374 replied the topic: OKA Paint Colour
It also depends on what colour your Oka is painted.
for those with Australian Camouflage the paint is made by Protec,they have branches in most states except the NT. Available in 4 litre, 1 litre and 400g spray cans and they are happy to post any orders.
The codes are Camouflage Green Lustreless 342-1166-23
Camouflage Brown Lustreless 342-5265-23
Camouflage Black Lustreless 342-7165-23
When applying paint the order is green first, then brown and finish up with black, no straight edges on colour patches and don't follow vehicle profiles.
Due to the high solid content it is best to warm the spray cans and shake very well before use or they do clog the nozzles.
25 Nov 2014 16:26 #5 by TH
The reason I can't find a paint tint code appears to be because there isn't one.
XT/LT are painted in International paints base white. No tint.
Cheers, Tony
25 Nov 2014 16:43 #6 by DarrenWebster303
DarrenWebster303 replied the topic: OKA Paint Colour
303 is Olive Drab 289 >>>3/207 . Current number is BS.381C.298. (Mine is minus the flattening agent at the end)
26 Nov 2014 04:35 #7 by Outback Jack
Outback Jack replied the topic: OKA Paint Colour
Would be good to get the original OKA paint.
Its pretty tough stuff, most OKA`s paint is not too bad even after 15 to 20 years..........
26 Nov 2014 09:05 - 26 Nov 2014 09:13 #8 by TH
It is very good quality paint. I have been using the same paint on spreaders and boomsprays for some time now. Very hardy.
Interthane 990 is the current incarnation 2pack from International. But if you don't need 4lts and are only doing touch-ups then Interlac 649 in 1lt with an enamel hardener is the best option.
Cheers, Tony
Last Edit: 26 Nov 2014 09:13 by TH.
27 Nov 2014 13:07 #9 by Hank Onthewater
Hank Onthewater replied the topic: OKA Paint Colour
Thanks Tony, as it so happens I purchased a can of spray a while ago, matched to the OKA according to their books, applied yesterday....... and the match is incorrect or the colour on OKA has changed...
Will try the Interthane next time
27 Nov 2014 13:30 #10 by Outback Jack
There is a paint code called OKA. It is a Toyota Corolla and other Toyota paint code. Not OKA colour code
Toyota call it diamond white 061. It is different to the Landcruiser white 058 I think for memory.
Original OKA`s paint is different again.
05 Dec 2014 08:03 #11 by TH
061 is different. OKA is a camry colour
I have tried the interlac 649 and sadly it dries to a slightly creamier white. An enamel thing apparently. INTERTHANE 990 2 pack is only avvailable as a 5lt kit. Azko Nobel don't seem interested in helping with colour so I contacted the Dupont supplier in Perth, Premier paints, and they have a spectrum analyser and can do 2 pack stunning white in any size you want. Sika white sikaflex is the same white as original XT/LT white.
Cheers, Tony
