fuel tank sender
25 Apr 2014 13:33 #1 by deedy
deedy created the topic: fuel tank sender
Hi I have bought 2 second hand tanks off a isuzu and a canter(both are the same tank). These tanks hold 125 litres each and I will need to make up a bracket. Can anyone tell me what vdo sender i need to buy. I believe it is the 10 to 180 ohm sender. Is this correct?
25 Apr 2014 13:45 #2 by Outback Jack
Outback Jack replied the topic: fuel tank sender
I think your right, but others should be able to confirm it.
Will be intrested to see how you go with new tanks
26 Apr 2014 04:40 #3 by Chris James
Chris James replied the topic: fuel tank sender
Deedy,can you give me the measurements for the 2 tanks please.I have a pair of 200lt tanks which will not work with my plan to change from a dual cab and rear canopy to a tray and slid on camper.I will not be able to get the nozzle in to fill them. Which model Isuzu was the tank from? Regards Chris.
Chris & Shirley 096
26 Apr 2014 05:56 #4 by Outback Jack
I wonder if one of these would fit underneath somewhere??
Some other options
Hilton tanks
Universal Fuel Tanks
Canter one may be cheaper option, Hiltons have a good selection.
26 Apr 2014 06:18 #5 by deedy
deedy replied the topic: fuel tank sender
Tank size 1100 long 400 diameter approx. Sorry I cont know what model it is the "Long" tank. It is very common on isuzu and canter trucks.
The following user(s) said Thank You: Chris James
26 Apr 2014 07:04 #6 by Outback Jack
Hiltons have the following
457 round and 850 long 130 Litres $490
457 round and 1100 long 165 Litres $500
02 Jan 2019 12:41 #7 by Ewart and Vivian Halford
Ewart and Vivian Halford replied the topic: fuel tank sender
Hi Deedy, did you get vdo gauges to suit you canter tanks.
02 Jan 2019 13:06 #8 by fran philipson
fran philipson replied the topic: fuel tank sender
Ian Jones has the fuel tank senders for the OKA. I got two new ones from him last year and fitted them to the new ally tanks I got from Chris at Kununurra. All works well.
