6bt intermittent no start
- tcgreen
I was thinking maybe the fuel cutoff solenoid is stickng closed????
Any ideas much appreciated.
Cheers Tony
Tony & Chris
Oka 334 motorhome.
As there are no butterfly (in a throttle body) and no spark plug... it somewhat reduces the variables compared to a petrol engine.
If it is turning over, then the only other thing is air and fuel assuming the compression is high.
As previously noted; there should not be much impeding the air from going in, so that leaves fuel.
Either the solenoid is:
1) no longer pushing hard enough when hot, or
2) when it is hot more push is required.
However any rubbish in the fuel can be bad... On a tractor, or similar engine, that usually results in an engine "bolting".
#2: I suppose any particles that may have gotten in could cause it to stick, or if the solenoid is 'tired' then being hot will increase resistance, and loose current flow, and therefore loose magnetic push.
I do not know what these look like on a 6BT... are there also some linkages and levers? of is it direct?
#1: I would likely put a volt meter on the solenoid to see what it is seeing for voltage. If the wire delivering the current is hot then the voltage drop will increase and that will also result in a lower slamming open of the solenoid... If it works at 12V, but not at 9 or 10V (or whatever), then you likely may need a new/fatter wire, or reroute it to keep it cooler. (I like Tefzel wire in general)
Hence I would do the volt meter first.
If it has a lever, then you could actuate by hand when hot and cold to get a feel for it. (or a spring scale or torque reading if you want to be precise). You may need some oven mitts...
This leads to low IP fuel housing pressure as everything is hot and "loose" due to the wear, let it cool down for a while and away it goes. Unfortunately the only cure is a replacement IP. Wagga diesel used to resleeve the IP with bronze so they may be able to reco a VE pump.
Check all the obvious first like the stop solenoid etc but the big test for a worn IP is when it is hot and won't start dump a bucket of very cold water slowly over the IP to cool it quickly and then try starting it if it starts straight away when cooled rapidly then the IP is the culprit.
This of course does only apply if you have a VE rotary IP rather than an inline P IP.
- tcgreen
Our previous vehicle was a landcruiser with a 1hz, with probably worn IP. It had instantaneous cold start, but needed a fair bit of cranking when hot. Our oka has the rotary IP, but behaves differently to the 1hz. The intermittent no start can be when the engine is hot or cold. The only consistant thing is that the no start occurs only when trying to start immediately after turning off the engine. I am hoping it is not the IP!
You all given me ideas on where to start looking. Will let you know how I go.
Tony & Chris
Oka 334 motorhome.
Joseph Baz wrote: Tony,some how and just out of gut feeling I don't think the problem is the IP (it won't be the first time that i was wrong). If you have access to a vacuum hand pump check all the fuel lines from the tank to the pump and make sure that all lines are good and vacuum tight before you embark in expensive fixes if all check OK them you can get a really good bottle of Scotch and forget about the price of a IP overhaul
Is there a lift pump on those engines?
It seems like it is either no getting fuel to the pump, or from the pump.
The solenoid idea, as well as Joe's words, both address fuel to the pump.
- tcgreen
Tony & Chris
Oka 334 motorhome.
- tcgreen
Tony & Chris
Oka 334 motorhome.
