Front driveshaft safety loop design.
28 Dec 2018 12:44 - 28 Dec 2018 12:48 #1
by Peter_n_Margaret
Peter_n_Margaret created the topic: Front driveshaft safety loop design.
From another thread....
In "normal" operations, it has previously touched the starter (but not done any damage).
I have fabricated (but not yet fitted) a new safety loop which will be bolted directly to the horizontal cast webs at the rear of the front diff housing. I will bolt it relatively close to the edges of those webs so in a major impact, it breaks bits off the webs rather than smash the diff housing.
It will be shorter and lighter than the original and in several pieces so I can remove it without dropping the tailshaft.
Anyone give me a good reason not to proceed with this?
In my recent "misadventure" with #196, the arm that holds the safety loop impacted the geared starter motor, completely destroying it.Peter and Sandra OKA 374 wrote: From the Oka parts manual, it is just an oval loop made of 25 x6mm flat bar on the end of the arm.
You do not have permissions to access this page.
Last Edit: 28 Dec 2018 12:48 by Peter_n_Margaret.
28 Dec 2018 14:06 - 28 Dec 2018 14:07 #2
by Holmz
Holmz replied the topic: Front driveshaft safety loop design.
As an idea...
if you parted the piece in the middle of the long RHS, then you could bolt a 125-mm long sleeve on both of the cuts... assuming that there is an RHS that is semi snug, Then the bolts should hold if they are M8 or bigger???
Last Edit: 28 Dec 2018 14:07 by Holmz.
28 Dec 2018 14:43 - 28 Dec 2018 14:44 #3
by Peter_n_Margaret
Peter_n_Margaret replied the topic: Front driveshaft safety loop design.
I think we are thinking in the same direction?
Some pics...
The Diff....
This bolts onto the flanges each side of the diff (it is up-side-down in the pic). It has to clear the universal joint. 2 x M8 bolts each side.
The loop bolts onto the bit above...(currently fabricated longer than it needs to be).
Some pics...
The Diff....
Last Edit: 28 Dec 2018 14:44 by Peter_n_Margaret.
29 Dec 2018 07:35 - 29 Dec 2018 07:38 #4
by Holmz
Personally If I was to bolt a girde/truss into the diff, then I would make it smethint strengthen the whole diff.
www.artecindustries.com/Modular_Truss_End
Then just hang your hoop off of that?
My hoop departed me factory 25mm RHS at the end... so I think something needs that be strong.
Last Edit: 29 Dec 2018 07:38 by Holmz.
29 Dec 2018 07:52 #5
by Peter_n_Margaret
Nice, but a whole new ball game
