Cable Gear Change
30 Oct 2012 13:12 - 30 Oct 2012 13:12 #1
dandjcr created the topic: Cable Gear Change
Forum Home > OKA Maintenance > Cable Gear Change
Marj Parsons
Does anyone have any experience of putting a cable gear change into an LT?
WE are in the process of changing the XT gear box and transfer case into an LT and would like to also include the cable gear change. A pattern of the pieces we need to cut out would be good, and instructions for fitting would be an advantage as well .We regularly do the difficult and even at times try for the impossible! Any help would be appredciated.
Lloyd Parsons
September 18, 2012 at 4:04 PM Flag Quote & Reply
I think others have changed to cable gear changes, perhaps contact Paul Nott or Alan
September 18, 2012 at 5:13 PM Flag Quote & Reply
OKAPETE .......... Peter and Sharon Furlong.
Hi Lloyd and Marge. we must catch up again sometime. I originally tracked down this company here in Vic as the OEM suppliers for the Oka cable gear change upgrade. I dont know if they still do anything or even exist but you could give them a try. God bless and have fun building 337. regards. Peter Furlong.
Tuthill Australia Pty Ltd Cables--Mechanical - Kilsyth, VIC 19-21/ 128 Canterbury Rd, Kilsyth VIC 3137, Australia (03) 9839 7800
September 18, 2012 at 6:31 PM Flag Quote & Reply
September 18, 2012 at 6:54 PM Flag Quote & Reply
OKAPETE .......... Peter and Sharon Furlong. at September 18, 2012 at 6:31 PM
Tuthill no longer exist, however.
If you speak to Rob Gallagher from
Cablecraft Australia P/L
Brendale, QLD Unit 2 - 15 Hinkler Crt, Brendale QLD 4500
(07) 3881 0400 This email address is being protected from spambots. You need JavaScript enabled to view it.
He worked for Tuthill for 20 years and knows the OKA`s well. They end up throwing out the cable shifters etc for the OKA.
September 19, 2012 at 12:44 PM
Marj Parsons
Lloyd Parsons
Last Edit: 30 Oct 2012 13:12 by dandjcr.
