Front Door Seals
30 Oct 2012 13:13 #1 by dandjcr
dandjcr created the topic: Front Door Seals
Forum Home > OKA Maintenance > Front Door Seals
Just a quick one... I went in to Autobarn today to replace the front door seal and even though it's a very common cross section I was met with a nearly $20/m price tag making each seal almost $80 and was just wondering if anyone had a better option?
Al
March 1, 2012 at 7:43 PM Flag Quote & Reply
Ovestco if they are near you
www.ovesco.com.au have a full on-=line catalogue with profiles and dimensions of seals.
March 1, 2012 at 8:08 PM Flag Quote & Reply
wessa #400
I replaced mine recently, of the shelf from Clark Rubber approx $12 per metre.
March 1, 2012 at 9:11 PM Flag Quote & Reply
I'll second tony on that, Ovesco have a good range and are heaps cheaper than places like Clark Rubber.
March 1, 2012 at 9:32 PM Flag Quote & Reply
Posts: 539 Recently needed some fuel tank strap rubber mouldings and Ovesco didn't have quite what I wanted so went to Clark rubber. They had an even worse selection and were double the price.
March 1, 2012 at 10:33 PM Flag Quote & Reply
Rick Whitworth
Spectrum rubber have the widest range..
www.spectrumrubber.com.au/images/stories...Rubber_Catalogue.pdf
Spectrum Catalogue uses the same moulding id as Clark rubber
They can supply almost any moulding with the exception of the flocked bailey channel used in standard OKA busbody windows. I could only source it through the origional OKA window maker Marine & Mobile Windows Myaree WA
March 1, 2012 at 11:08 PM Flag Quote & Reply
If your in/near Adelaide, I replaced the door seals from Fitch the Rubber Man several years ago. Wasn't a cheap job but they had all the profiles and almost anything else in rubber, including tank strapping.
Sounds like a few things to add to the Parts Listing.
March 1, 2012 at 11:46 PM Flag Quote & Reply
frank
If you're in Perth.
Industrial Rubber Supplies
102 Briggs Street Welshpool WA 6106
(08) 9362 5044
March 2, 2012 at 12:22 AM Flag Quote & Reply
John & Laura Szkoruda
As Rick said, Spectrum Rubber products in St Marys NSW have most all rubber profiles for the Oka, we have replaced door seals, boot seal, windscreen rubbers etc all from Spectrum they are cheaper than Clark Rubber and post anywhere.
Cheers John & Laura
John & Laura Szkoruda OKA 147
March 2, 2012 at 9:05 AM Flag Quote & Reply
Any one have part numbers for Spectrum Rubber?
September 19, 2012 at 10:46 AM
