Welcome to the OKA forum!
Looking for an Oka
- Dan
06 Jan 2015 08:59 #1
by Dan
Dan created the topic: Looking for an Oka
Hi all
Im Dan
I currently own and use a 2006 78 Series Troopcarrier 1HD-FTE 4.2DI Turbo.
I've been on the road for 10 weeks relocating to Perth.
Im now looking for an Oka to buy to use as a long range tourer and long term live in vehicle.
Got the bug for the Oka a couple of yrs back after seeing one in Cairns.
Im currently looking at a few in different places, NSW, SA and Coolgardie in WA.
Are there really 1 owner from new vehicles still out there, is it possible to have an Oka 1993 with only 124,000km on the clock?
Any info or help on what to buy or not to buy would be helpful.
Dan
Im Dan
Dan
06 Jan 2015 09:14 - 07 Jan 2015 08:52 #2
by outyonda
outyonda replied the topic: Looking for an Oka
We bought #091 new & has been used Dailey over harvest.
there is still a few one owners out there with low KM's
I have #094 tray back for sale. the one in the middle.
will be in Perth next week with it
ph 98832020
M 0429 831040
Brett
ph 98832020
M 0429 831040
Brett
Last Edit: 07 Jan 2015 08:52 by outyonda.
06 Jan 2015 09:37 - 06 Jan 2015 09:41 #3
by Dean and Kaye Howells
Hi Dan,
Whilst there may still be one owner low km OKA's out there don't let this be the major criteria in your selection of one. If the 'one owner' has been a mining company or tour operator the OKA will have been well used and may be (over)due for major overhaul. Don't let this totally put you off though as the OKA was designed to be seriously used and to be pulled down for refurbishment. It is not a big deal to do this if you can 'spin a spanner'. With any 20+ year old vehicle it's not just the physical wear and tear but 'ageing' of components especially rubber and plastic parts that will need replacing regardless of Kms travelled.
The OKA is a very basic machine and most parts are readily available either from Alan over there in WA or Paul Nott and Ian Jones here in Victoria and possibly others. Be careful of buying parts elsewhere, eBay for example, as they may claim to fit the OKA and look similar eg. brake master cylinder, but not suitable and in some cases eg. wheel bearings, disc pads and rotors, extremely over priced.
OKA Pete over here is worth contacting as he deals in used OKA's.
Dean and Kaye Howells replied the topic: Looking for an Oka
Dan wrote: Hi all
.....................Are there really 1 owner from new vehicles still out there, is it possible to have an Oka 1993 with only 124,000km on the clock?
Dan
Hi Dan,
Last Edit: 06 Jan 2015 09:41 by Dean and Kaye Howells. Reason: more info
The following user(s) said Thank You: Dan
- Dan
06 Jan 2015 12:15 #4
by Dan
Dan replied the topic: Looking for an Oka
Thanks for the heads up Deano
- The Worb
06 Jan 2015 17:09 #5
by The Worb
The Worb replied the topic: Looking for an Oka
Hi Dan,
I bought 351 a couple of years ago now and I was the third owner.
Purchased with just 170k on the clock. It hadn't been in the mines
and was purchased and converted by the first owner, then re converted
by the second and then re converted again by me.
I still get comments about my new vehicle and when I tell them it is
a 1995 model, they can't believe it.
I think the moral is to not jump in too quick and buy when you are
ready and happy with your purchase.
Cheers and happy oka'ring in the future.
Brian
Brian
- TH
06 Jan 2015 17:26 #6
by TH
Cheers, Tony
TH replied the topic: Looking for an Oka
Hi Dan. Yes they do exist. I found a 1 owner camper with 80 odd K on the clock with a 135Ti under the engine cover. Very happy with my choice.
The electronic speedo has a habit of stripping gears and not counting km's around 70-100K km's so check the speedo is spinning numbers and ask the question.
The history of most OKA's build numbers is easy to trace through Alan at OKAParts or on here.
There are a few good vehicles on the market atm. Gumtree has several listings.
As Deano said, don't rush and feel free to ask shitloads of questions on here.
Cheers, Tony
06 Jan 2015 21:05 #7
by Outback Jack
Outback Jack replied the topic: Looking for an Oka
As all states above.
Dont let KMS or Age determine your choice.
Ask lots of questions, Learn as much as you can.
OKA`s have several common design faults, nothing terminal.
Plenty of knowledge here and most OKA` history is known to someone here. Or Al at OKA Parts.
- Hank Onthewater
07 Jan 2015 08:28 #8
by Hank Onthewater
Hank Onthewater replied the topic: Looking for an Oka
Hi Dan
I bought my campervan from its first owner with 69k Km on the clock (that was nearly 4 years ago). Mick bought his (OKA #236, that now 'Rainmaker' owns) with 21k Km (that was a mining company firetruck).
As others said already it is not the low Km what may be important, more so how it was used and maintained.
- Matt
28 Mar 2015 15:26 #9
by Matt
Matt replied the topic: Looking for an Oka
Hi Dan
Are you still looking for a Oka. I have a lawn queen that i am hopping to re-home due to a new house she needs a lot of work have most of the replacment parts.
you can call me any time 0409475870
